简介
Shows steps of disassembling Samsung SyncMaster 205BW monitor.
你所需要的
Back of the monitor. Remove the two screws at the top of the stand.
Silver edge removed and placed under the body with metal back. Black cover removed. The front panel cable connects to the bottom right of the body. Remove it. Remove the metal cover on top right by pulling it slightly on the edge at the top. This allows the two hooks on the slanting edge of the metal bracket to be unhooked.
The metal bracket with circuit boards. The smaller circuit board: * two screws (bottom left, bottom right) * four screw extenders at the sides of the connectors The larger circuit board: * two black screws (bottom left, top middle) * one silver screw with washer that holds a metal strip and circuit board (top left)
5等其他人完成本指南。
