跳转到主内容
Disassembling Samsung Gravity SGH-T459 Keypad
你所需要的
  1. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Back Cover: 步骤 1 中的图像 1,1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Battery: 步骤 2 中的图像 1,1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: 步骤 3 中的图像 1,3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: 步骤 3 中的图像 2,3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: 步骤 3 中的图像 3,3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: 步骤 4 中的图像 1,3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: 步骤 4 中的图像 2,3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: 步骤 4 中的图像 3,3
    • Gently remove the two button contacts with your fingers.
    • Use a plastic prying tool to pry the keypad away from the circuit board.
    • Use tweezers to gently remove the keypad.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 736
