跳转到主内容
Disassembling Samsung Gear 2 Front half and Back half
你所需要的
  1. Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: 步骤 1 中的图像 1,2 Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: 步骤 1 中的图像 2,2
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Disassembling Samsung Gear 2 Front half and Back half: 步骤 2 中的图像 1,1
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Disassembling Samsung Gear 2 Front half and Back half: 步骤 3 中的图像 1,3 Disassembling Samsung Gear 2 Front half and Back half: 步骤 3 中的图像 2,3 Disassembling Samsung Gear 2 Front half and Back half: 步骤 3 中的图像 3,3
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
结论
4等其他人完成本指南。
Jonathan Molina
于04/14/14注册
1,018 声望
创作了2篇指南
团队
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G27
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,234
