跳转到主内容
Disassembling Samsung Galaxy S Blaze Whole Device
你所需要的
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 1 中的图像 1,1
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 2 中的图像 1,1
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 3 中的图像 1,2 Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 3 中的图像 2,2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 4 中的图像 1,1
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 5 中的图像 1,1
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 6 中的图像 1,1
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 7 中的图像 1,1
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 8 中的图像 1,3 Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 8 中的图像 2,3 Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 8 中的图像 3,3
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 9 中的图像 1,1
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: 步骤 10 中的图像 1,1
    • All of the parts are seen here.
结论
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
2等其他人完成本指南。
Jake Best
于03/05/15注册
261 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 761
