跳转到主内容
加入维修社区 - 创建账户
Disassembling Samsung Captivate Glide Phone
你所需要的
  1. Disassembling Samsung Captivate Glide Phone, Phone: 步骤 1 中的图像 1,3 Disassembling Samsung Captivate Glide Phone, Phone: 步骤 1 中的图像 2,3 Disassembling Samsung Captivate Glide Phone, Phone: 步骤 1 中的图像 3,3
    • The Samsung Captivate Glide is fairly easy to take apart and replace any of the modular internal components
  2. Disassembling Samsung Captivate Glide Phone, Battery Removal: 步骤 2 中的图像 1,3 Disassembling Samsung Captivate Glide Phone, Battery Removal: 步骤 2 中的图像 2,3 Disassembling Samsung Captivate Glide Phone, Battery Removal: 步骤 2 中的图像 3,3
    • First remove the battery
  3. Disassembling Samsung Captivate Glide Phone, Unscrewing the Back: 步骤 3 中的图像 1,1
    • Using the Phillips #00 screwdriver remove the seven screws indicated here.
  4. Disassembling Samsung Captivate Glide Phone, Prying Up The Back: 步骤 4 中的图像 1,3 Disassembling Samsung Captivate Glide Phone, Prying Up The Back: 步骤 4 中的图像 2,3 Disassembling Samsung Captivate Glide Phone, Prying Up The Back: 步骤 4 中的图像 3,3
    • Plastic molded clips hold the back panel in place and can be removed by first inserting the plastic opening tool into the indicated locations and prying up to pop the back up.
    • Then using a wider lipped plastic opening tool pry the outside of the housing up and the back will remove cleanly.
  5. Disassembling Samsung Captivate Glide Phone, The Phone's Innards: 步骤 5 中的图像 1,3 Disassembling Samsung Captivate Glide Phone, The Phone's Innards: 步骤 5 中的图像 2,3 Disassembling Samsung Captivate Glide Phone, The Phone's Innards: 步骤 5 中的图像 3,3
    • Shown here are internals of the phone.
  6. Disassembling Samsung Captivate Glide Phone, Motherboard Removal: 步骤 6 中的图像 1,3 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: 步骤 6 中的图像 2,3 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: 步骤 6 中的图像 3,3
    • In order to remove the motherboard remove a single screw with the phillips #00 screwdriver, gently pry up the two pop connectors on the board, and finally pull off the coaxial cable.
  7. Disassembling Samsung Captivate Glide Phone, Motherboard Removal: 步骤 7 中的图像 1,2 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: 步骤 7 中的图像 2,2
    • The motherboard comes out of the phone body easily.
  8. Disassembling Samsung Captivate Glide Phone, Daughterboard Removal: 步骤 8 中的图像 1,2 Disassembling Samsung Captivate Glide Phone, Daughterboard Removal: 步骤 8 中的图像 2,2
    • The modular pieces of the motherboard are easily removed and replaced as needed.
    • First the daughter board containing the SIM card and microSD card can be removed by disconnecting a single pop connector from the board and then gently pry the daughter board up and it will come loose. It is held down to the motherboard by the stamped metal board level shielding cages.
  9. Disassembling Samsung Captivate Glide Phone, Camera Removal: 步骤 9 中的图像 1,1
    • The camera can be easily removed from the motherboard by pulling up on the board pop connector.
  10. Disassembling Samsung Captivate Glide Phone, Speaker Removal: 步骤 10 中的图像 1,1
    • The speaker is also easily removed by pulling up on the pop connector.
  11. Disassembling Samsung Captivate Glide Phone, The Disassembled Motherboard: 步骤 11 中的图像 1,2 Disassembling Samsung Captivate Glide Phone, The Disassembled Motherboard: 步骤 11 中的图像 2,2
    • Shown here are all the pieces of the motherboard.
  12. Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: 步骤 12 中的图像 1,3 Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: 步骤 12 中的图像 2,3 Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: 步骤 12 中的图像 3,3
    • The antenna module can be removed by disconnecting the coaxial cable and a single phillips #00 screw.
    • The antenna module can be prying upward at the location indicated.
  13. Disassembling Samsung Captivate Glide Phone, Antenna Module: 步骤 13 中的图像 1,1
    • Shown here is the antenna module.
  14. Disassembling Samsung Captivate Glide Phone, Base and Screen: 步骤 14 中的图像 1,1
    • The screen and base are shown here.
结论
3等其他人完成本指南。
alcs99
于09/10/13注册
5,075 声望
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 80
总计 3,731
