跳转到主内容
Disassembling SKIL 4235 Jigsaw Base plate
你所需要的
  1. Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: 步骤 1 中的图像 1,3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: 步骤 1 中的图像 2,3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: 步骤 1 中的图像 3,3
    • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
  2. Disassembling SKIL 4235 Jigsaw Base plate: 步骤 2 中的图像 1,1
    • Using two hands grip both side of the saw and lay on side.
  3. Disassembling SKIL 4235 Jigsaw Base plate: 步骤 3 中的图像 1,1
    • With bottom of the base plate visible, identify one M4 screw circled in red and remove with Phillips screwdriver (some models have flathead screw, as pictured, and require flathead screwdriver).
  4. Disassembling SKIL 4235 Jigsaw Base plate: 步骤 4 中的图像 1,1
    • After removing M4 screw, remove the base plate and place to the side. Don't forget to replace the M4 screw near the base plate during re-installation.
结论
另外一个人完成了本指南。
Adam Cardoso
于11/12/13注册
357 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-8, Vijaybhaskar Fall 2013 的会员
UMASSD-VIJAYBHASKAR-F13S4G8
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 3,041
