跳转到主内容
Disassembling RCA RCT6272W23 Case
你所需要的
  1. Disassembling RCA RCT6272W23 Case, Disassembling RCA RCT6272W23 Case: 步骤 1 中的图像 1,2 Disassembling RCA RCT6272W23 Case, Disassembling RCA RCT6272W23 Case: 步骤 1 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. Disassembling RCA RCT6272W23 Case: 步骤 2 中的图像 1,2 Disassembling RCA RCT6272W23 Case: 步骤 2 中的图像 2,2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
结论
2等其他人完成本指南。
团队
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G5
2 名成员
创作了12篇指南
一条评论
boi this it too easy
murphy mcgrath - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 812
