跳转到主内容
Disassembling RCA CC310 Left Cover
你所需要的
  1. Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: 步骤 1 中的图像 1,2 Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: 步骤 1 中的图像 2,2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. Disassembling RCA CC310 Left Cover: 步骤 2 中的图像 1,2 Disassembling RCA CC310 Left Cover: 步骤 2 中的图像 2,2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. Disassembling RCA CC310 Left Cover: 步骤 3 中的图像 1,2 Disassembling RCA CC310 Left Cover: 步骤 3 中的图像 2,2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. Disassembling RCA CC310 Left Cover: 步骤 4 中的图像 1,2 Disassembling RCA CC310 Left Cover: 步骤 4 中的图像 2,2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
结论
团队
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G20
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,158
