跳转到主内容
Disassembling Quasar Microwave Outer Cover
你所需要的
  1. Disassembling Quasar Microwave Outer Cover, Disassembling Quasar Microwave Outer Cover: 步骤 1 中的图像 1,1
    • Disconnect the power supply cord from the outlet.
  2. Disassembling Quasar Microwave Outer Cover: 步骤 2 中的图像 1,2 Disassembling Quasar Microwave Outer Cover: 步骤 2 中的图像 2,2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Disassembling Quasar Microwave Outer Cover: 步骤 3 中的图像 1,2 Disassembling Quasar Microwave Outer Cover: 步骤 3 中的图像 2,2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Disassembling Quasar Microwave Outer Cover: 步骤 4 中的图像 1,3 Disassembling Quasar Microwave Outer Cover: 步骤 4 中的图像 2,3 Disassembling Quasar Microwave Outer Cover: 步骤 4 中的图像 3,3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
结论
3等其他人完成本指南。
Samuel
于09/26/12注册
142 声望
创作了2篇指南
团队
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G12
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 2,576
