跳转到主内容
Disassembling Qualcomm QCP-2760 Rear Backing
你所需要的
  1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: 步骤 1 中的图像 1,1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: 步骤 2 中的图像 1,2 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: 步骤 2 中的图像 2,2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
结论
Xavier
于10/02/14注册
313 声望
创作了3篇指南
团队
Ohio State, Team 1-4, Buehl Fall 2014 Ohio State, Team 1-4, Buehl Fall 2014 的会员
OSU-BUEHL-F14S1G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 201
