跳转到主内容
Disassembling Power Mac G4 M5183 DVD-ROM Drive
你所需要的
  1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 1,2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: 步骤 1 中的图像 2,2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: 步骤 2 中的图像 1,2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: 步骤 2 中的图像 2,2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: 步骤 3 中的图像 1,1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Disassembling Power Mac G4 M5183 DVD-ROM Drive: 步骤 4 中的图像 1,3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: 步骤 4 中的图像 2,3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: 步骤 4 中的图像 3,3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
  5. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: 步骤 5 中的图像 1,3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: 步骤 5 中的图像 2,3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: 步骤 5 中的图像 3,3
    • Remove DVD drive from the drive bay.
    • Lift the two metal tabs on the back of the shielding and remove.
    • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
    • Slide out DVD drive.
结论
12等其他人完成本指南。
Stephen Scruggs
于01/20/10注册
2,259 声望
创作了2篇指南
团队
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G24
4 名成员
创作了37篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 11,727
