跳转到主内容
加入维修社区 - 创建账户
Disassembling Power Mac G4 Cube Outer Case
你所需要的
  1. Disassembling Power Mac G4 Cube Outer Case, Outer Case: 步骤 1 中的图像 1,3 Disassembling Power Mac G4 Cube Outer Case, Outer Case: 步骤 1 中的图像 2,3 Disassembling Power Mac G4 Cube Outer Case, Outer Case: 步骤 1 中的图像 3,3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Disassembling Power Mac G4 Cube Outer Case: 步骤 2 中的图像 1,2 Disassembling Power Mac G4 Cube Outer Case: 步骤 2 中的图像 2,2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Disassembling Power Mac G4 Cube Outer Case: 步骤 3 中的图像 1,1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Disassembling Power Mac G4 Cube Outer Case: 步骤 4 中的图像 1,1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
结论
8等其他人完成本指南。
Ryan Chun
于06/24/10注册
1,076 声望
创作了7篇指南
团队
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G7
5 名成员
创作了21篇指南
1指南评论
This does not describe the disassembly of the outer case! Just how to remove the inter case. If you need to clean the outer case this instruction is of no use.
jt - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 19
过去 30 天: 70
总计 12,410
