跳转到主内容
Disassembling Polaroid a520 Logic Board
你所需要的
  1. Disassembling Polaroid a520 Logic Board, Battery: 步骤 1 中的图像 1,2 Disassembling Polaroid a520 Logic Board, Battery: 步骤 1 中的图像 2,2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Disassembling Polaroid a520 Logic Board: 步骤 2 中的图像 1,1
    • Remove the batteries from the camera.
  3. Disassembling Polaroid a520 Logic Board, Casing: 步骤 3 中的图像 1,1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Disassembling Polaroid a520 Logic Board: 步骤 4 中的图像 1,1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Disassembling Polaroid a520 Logic Board, LCD Screen: 步骤 5 中的图像 1,1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Disassembling Polaroid a520 Logic Board: 步骤 6 中的图像 1,1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
  7. Disassembling Polaroid a520 Logic Board, Logic Board: 步骤 7 中的图像 1,1
    • Unscrew and remove the four (6 mm) screws on the inside casing.
  8. Disassembling Polaroid a520 Logic Board: 步骤 8 中的图像 1,1
    • Pull the inner casing off of the camera.
  9. Disassembling Polaroid a520 Logic Board: 步骤 9 中的图像 1,1
    • Unscrew and remove the four (4mm) screws from the logic board.
  10. Disassembling Polaroid a520 Logic Board: 步骤 10 中的图像 1,1
    • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
结论
Dani
于06/24/10注册
21 声望
创作了7篇指南
团队
Cal Poly, Team 3-3, Johann Summer 2010 Cal Poly, Team 3-3, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G3
2 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,068
