跳转到主内容
Polaroid a520 LCD Screen Replacement
你所需要的
  1. Polaroid a520 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Polaroid a520 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Polaroid a520 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the camera.
  3. Polaroid a520 LCD Screen Replacement, Casing: 步骤 3 中的图像 1,1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Polaroid a520 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Polaroid a520 LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 1,1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Polaroid a520 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
结论
Dani
于06/24/10注册
21 声望
创作了7篇指南
团队
Cal Poly, Team 3-3, Johann Summer 2010 Cal Poly, Team 3-3, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G3
2 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,670
