跳转到主内容
Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide)
你所需要的
视频概述
  1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: 步骤 1 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: 步骤 1 中的图像 2,2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 2 中的图像 1,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 2 中的图像 2,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 2 中的图像 3,3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 3 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 3 中的图像 2,2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 4 中的图像 1,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 4 中的图像 2,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 4 中的图像 3,3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 5 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 5 中的图像 2,2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 6 中的图像 1,1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 7 中的图像 1,1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 8 中的图像 1,1
    • Separate the front and rear cases.
  9. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: 步骤 9 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: 步骤 9 中的图像 2,2
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 10 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 10 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 11 中的图像 1,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 11 中的图像 2,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 11 中的图像 3,3
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
结论
6等其他人完成本指南。
djgodmandj
于10/24/14注册
284 声望
撰写一个指南
1指南评论
So is there any chance that this could be used as a modding possibility, where we could install a higher resolution /quality screen?
TheHeavy - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 48
过去 30 天: 185
总计 8,506
