跳转到主内容
Disassembling Planet Eclipse Etha Frame
你所需要的
  1. Disassembling Planet Eclipse Etha Frame, Regulator: 步骤 1 中的图像 1,2 Disassembling Planet Eclipse Etha Frame, Regulator: 步骤 1 中的图像 2,2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Disassembling Planet Eclipse Etha Frame: 步骤 2 中的图像 1,2 Disassembling Planet Eclipse Etha Frame: 步骤 2 中的图像 2,2
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: 步骤 3 中的图像 1,2 Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: 步骤 3 中的图像 2,2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Disassembling Planet Eclipse Etha Frame: 步骤 4 中的图像 1,1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Disassembling Planet Eclipse Etha Frame: 步骤 5 中的图像 1,2 Disassembling Planet Eclipse Etha Frame: 步骤 5 中的图像 2,2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Disassembling Planet Eclipse Etha Frame, Frame: 步骤 6 中的图像 1,2 Disassembling Planet Eclipse Etha Frame, Frame: 步骤 6 中的图像 2,2
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Disassembling Planet Eclipse Etha Frame: 步骤 7 中的图像 1,2 Disassembling Planet Eclipse Etha Frame: 步骤 7 中的图像 2,2
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Disassembling Planet Eclipse Etha Frame: 步骤 8 中的图像 1,1
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
结论
nicholasj6
于10/14/14注册
261 声望
创作了2篇指南
团队
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G42
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 13
总计 415
