跳转到主内容
Disassembling Piaggio X9 500 Exhaust Removal
你所需要的
  1. Disassembling Piaggio X9 500 Exhaust Removal, Disassembling Piaggio X9 500 Exhaust Removal: 步骤 1 中的图像 1,2 Disassembling Piaggio X9 500 Exhaust Removal, Disassembling Piaggio X9 500 Exhaust Removal: 步骤 1 中的图像 2,2
    • Loosen the exhaust strap:
    • Use an 12mm wrench to loosen the exhaust band lock nut.
    • A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
    • The Allen bolt is screwed into a loose nut in a cavity cast into the swing arm. It may fall out or become twisted. A magnet is helpful in retrieving it to re-align it for reassembly.
    • Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
  2. Disassembling Piaggio X9 500 Exhaust Removal: 步骤 2 中的图像 1,1
    • Use a 13mm socket to loosen the clamp between the muffler and header pipe.
    • You do not need to remove the bolt, but you want to loosen the clamp enough to allow the exhaust to be removed without damaging the gasket between the muffler and header pipe.
  3. Disassembling Piaggio X9 500 Exhaust Removal: 步骤 3 中的图像 1,1
    • A Torx T40 driver is required to remove the final bolt securing the exhaust.
    • The Exhaust assembly is now free. Pull and wiggle the muffler back (taking care not to damage your exhaust joint gasket) until the muffler comes free from the header pipe.
结论
2等其他人完成本指南。
Eric Essen
于06/04/10注册
17,792 声望
创作了8篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,757篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 26
总计 4,678
