简介
In this guide we will be removing the diffuser and the bottom panel of this lamp. This is necessary to access the electronic boards.
你所需要的
WARNING Make sure that the power cord of the lamp is unplugged and thus you will not encounter any live wire that tend to hurt...
Stand the lamp up on a table and slightly press on the top gray panel of the lamp.
20等其他人完成本指南。
12条评论
Hi,
The guide was very helpful as I just received such lamp for checking from one friend.
I would make only make one correction: you do not have to cut the plastic snap-ins, none of them.
If you use an IPhone opening toll kit, with those plastic levers as here:
[关联产品丢失或禁用: IF145-000]
then you can open it easy, without any scratches.
im wondering whether its possible to overwrite the wake sounds...
Chris Mair - 回复
Thank you so much for this guide. Was just about to give up on my lamp and buy and inferior led version when I found this.
These steps also work for the 3740 but the tabs holding the shade on (steps 8-10) are a different style. More like the ones on the bottom trim piece. Had to really work them and muscle that part off.
My ceramic bulb holder is severely corroded to the point where the light will only turn on if you jiggle the bulb. A little sad to see that the wires going to it are permanently attached on both ends. Now that the whole thing is apart. I'm going to see if I can source a new bulb holder and splice it onto the top...
