跳转到主内容
Disassembling Philips Portable Speaker SBA1610 37 Battery Casing
你所需要的
  1. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing, Battery Casing: 步骤 1 中的图像 1,1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 步骤 2 中的图像 1,3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 步骤 2 中的图像 2,3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 步骤 2 中的图像 3,3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 步骤 3 中的图像 1,2 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 步骤 3 中的图像 2,2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
结论
另外一个人完成了本指南。
团队
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 4,702
