跳转到主内容
加入维修社区 - 创建账户
Disassembling Pentax K200D Front Cover
你所需要的
  1. Disassembling Pentax K200D Front Cover, Preparation: 步骤 1 中的图像 1,1
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
    询问修复机器人
  2. Disassembling Pentax K200D Front Cover, Flash: 步骤 2 中的图像 1,1
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: 步骤 3 中的图像 1,1
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
    询问修复机器人
  4. Disassembling Pentax K200D Front Cover: 步骤 4 中的图像 1,1
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
    询问修复机器人
结论
9等其他人完成本指南。
团队
Master Techs Master Techs 的会员
Community
333 名成员
创作了1,479篇指南
1指南评论
How do l clean the prisum…
brett_lorking - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 101
总计 7,670
