跳转到主内容
Disassembling Panasonic Lumix DMC-TZ5 Back Cover
你所需要的
  1. Disassembling Panasonic Lumix DMC-TZ5 Back Cover, Back Cover: 步骤 1 中的图像 1,1
    • Remove the battery and memory card from the device.
  2. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 步骤 2 中的图像 1,1
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 步骤 3 中的图像 1,1
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 步骤 4 中的图像 1,1
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 步骤 5 中的图像 1,1
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 步骤 6 中的图像 1,2 Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 步骤 6 中的图像 2,2
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 步骤 7 中的图像 1,1
    • Remove the back casing from the camera.
结论
4等其他人完成本指南。
Ben Canfield
于10/10/10注册
409 声望
创作了3篇指南
团队
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G21
4 名成员
创作了14篇指南
一条评论
That is not a disassembly! All is shows is taking the back of the camera off. How about showing how to disassembly the camera down to its individual components and make repairs, like getting the lens to extend of fixing a sticking shutter.
JR Tan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 6,943
