跳转到主内容
Panasonic KX-E603 Case Replacement
你所需要的
  1. Panasonic KX-E603 Case Replacement, Case: 步骤 1 中的图像 1,2 Panasonic KX-E603 Case Replacement, Case: 步骤 1 中的图像 2,2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Case Replacement: 步骤 2 中的图像 1,1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Case Replacement: 步骤 3 中的图像 1,1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Case Replacement: 步骤 4 中的图像 1,2 Panasonic KX-E603 Case Replacement: 步骤 4 中的图像 2,2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Case Replacement: 步骤 5 中的图像 1,2 Panasonic KX-E603 Case Replacement: 步骤 5 中的图像 2,2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Case Replacement: 步骤 6 中的图像 1,3 Panasonic KX-E603 Case Replacement: 步骤 6 中的图像 2,3 Panasonic KX-E603 Case Replacement: 步骤 6 中的图像 3,3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Case Replacement: 步骤 7 中的图像 1,2 Panasonic KX-E603 Case Replacement: 步骤 7 中的图像 2,2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Case Replacement: 步骤 8 中的图像 1,2 Panasonic KX-E603 Case Replacement: 步骤 8 中的图像 2,2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Case Replacement: 步骤 9 中的图像 1,3 Panasonic KX-E603 Case Replacement: 步骤 9 中的图像 2,3 Panasonic KX-E603 Case Replacement: 步骤 9 中的图像 3,3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 11
总计 382
