跳转到主内容
加入维修社区 - 创建账户
Disassembling Panasonic GU87 Main-LCD
你所需要的
  1. Disassembling Panasonic GU87 Main-LCD, LCD Cover removal: 步骤 1 中的图像 1,1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 Main-LCD: 步骤 2 中的图像 1,1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 Main-LCD, LCD: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 Main-LCD: 步骤 4 中的图像 1,1
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  5. Disassembling Panasonic GU87 Main-LCD, Main Board: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Unlock the LCD connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  6. Disassembling Panasonic GU87 Main-LCD: 步骤 6 中的图像 1,1
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  7. Disassembling Panasonic GU87 Main-LCD: 步骤 7 中的图像 1,1
    • Pull/pivot the LCD main board as shown in order to remove.
  8. Disassembling Panasonic GU87 Main-LCD, Disassembling Panasonic GU87 Main-LCD: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
结论
Van
于06/24/10注册
7 声望
创作了8篇指南
团队
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G10
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,296
