跳转到主内容
Disassembling Panasonic GU87 Main Board removal
你所需要的
  1. Disassembling Panasonic GU87 Main Board removal, Battery: 步骤 1 中的图像 1,1
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Disassembling Panasonic GU87 Main Board removal: 步骤 2 中的图像 1,1
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Back cover: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the rubber covers with tweezers.
  4. Disassembling Panasonic GU87 Main Board removal: 步骤 4 中的图像 1,1
    • Remove all 4 screws from the back of the phone.
  5. Disassembling Panasonic GU87 Main Board removal: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to separate the front and back casing.
  6. Disassembling Panasonic GU87 Main Board removal: 步骤 6 中的图像 1,1
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
  7. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Main Board removal: 步骤 7 中的图像 1,1
    • Lift the main board over.
  8. Disassembling Panasonic GU87 Main Board removal: 步骤 8 中的图像 1,1
    • Pry the connector with finger nails.
结论
Van
于06/24/10注册
7 声望
创作了8篇指南
团队
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G10
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,779
