跳转到主内容
修复你的物品
维修的权力
配件 & 工具
配件
没有特定配件。
  1. Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Remove the rubber covers with tweezers.
    • Remove the rubber covers with tweezers.
  4. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  5. Remove all 4 screws from the back of the phone.
    • Remove all 4 screws from the back of the phone.
  6. Use a plastic opening tool to separate the front and back casing.
    • Use a plastic opening tool to separate the front and back casing.
  7. Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
  8. Lift the main board over.
    • Lift the main board over.
  9. Pry the connector with finger nails.
    • Pry the connector with finger nails.
结论
Van
于2010年06月24日注册
7 信誉积分
创作了8篇指南
团队
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G10
4 名成员
创作了20篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,687
