跳转到主内容
Disassembling Palm Zire 72v1
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Disassembling Palm Zire 72v1, Zire 72v1: 步骤 1 中的图像 1,1
    • Power off your Zire 72 and turn the unit over.
    • Remove the two screws on the bottom of the rear of the unit.
    • Peel back the information sticker.
    • Remove the one screw that connects the metal panel to the body of the Zire72.
    • Use the tip of your screwdriver to pop the metal panel off the top of the rear of the unit to expose two more screws on the top corners.
  2. Disassembling Palm Zire 72v1: 步骤 5 中的图像 1,2 Disassembling Palm Zire 72v1: 步骤 5 中的图像 2,2
    • Remove the two top screws.
    • Insert the tip of your screwdriver in the seam where the front frame meets the body of the unit and pry the frame up to pop it off. Remove it.
  3. Disassembling Palm Zire 72v1: 步骤 7 中的图像 1,1
    • Pull the back panel off the body of the unit to expose the motherboard in the body.
    • Unplug the two orange ribbon cables at the top of the motherboard and remove the motherboard from the body. All that is left is the LCD screen in the front housing of the unit.
  4. Disassembling Palm Zire 72v1: 步骤 9 中的图像 1,1
    • Remove the screen from the front housing and set it aside.
    • Now that you have your Zire open, you can remove and replace the defective part.
结论
Lisa
于09/08/11注册
13 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 112
