跳转到主内容
简介
By far the most common fault with headphones is a broken lead or cushion. If the break is within the headphones themselves or at that end of the lead you will need to disassemble them in order to replace the lead or shorten it to eliminate the break.
配件
没有特定配件。
  1. Use two or three fingers slowly pull the cushion. Caution: go gently and try not to apply too much force. Caution: go gently and try not to apply too much force.
    • Use two or three fingers slowly pull the cushion.
    • Caution: go gently and try not to apply too much force.
  2. By feel, locate 4 screws under the foam, 2 each side. Scrap away just sufficient foam in order to be able to remove the screws, and remove them.
    • By feel, locate 4 screws under the foam, 2 each side.
    • Scrap away just sufficient foam in order to be able to remove the screws, and remove them.
  3. The speaker assembly is now held in the shell just be a number of tabs around the edges. Gently prise it out from these tabs and remove it. Take care not to strain the wires.
    • The speaker assembly is now held in the shell just be a number of tabs around the edges. Gently prise it out from these tabs and remove it.
    • Take care not to strain the wires.
    • On reassembly, make sure the headband fork is correctly positioned otherwise it will be impossible locate the speaker faceplate correctly in the shell.
    • Also on reassembly, make sure the speaker face plate is secured behind all the tabs.
  4. On the right side connection are made via a small printed circuit board. Remove 2 screws in order to remove this for re-soldering or replacement of any of the wires. On replacing this circuit board, take care to ensure that it's both the right way round and the right way up
    • On the right side connection are made via a small printed circuit board. Remove 2 screws in order to remove this for re-soldering or replacement of any of the wires.
    • On replacing this circuit board, take care to ensure that it's both the right way round and the right way up
    • If you are replacing the main lead with the jack plug on the end, make sure that you have suitable strain relief to prevent the lead pulling on the soldered connections.
    • The wire colours are:
    • Right: Red
    • Left: Green
    • Common (Ground): Gold.
  5. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  6. Insert wisdom here. Insert wisdom here. Insert wisdom here.
结论
Camera used : lumia 520
7等其他人完成本指南。
forevergoku
于2014年11月29日注册
307 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 14
过去的30天: 68
总计 8,345
