当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Remove the top screw on the back panel.
Slide off the case to expose the internal components of the receiver.
Unscrew the three screws on top of the face plate.
Unscrew the one screw on the bottom of the front panel.
Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与7其他贡献者
于04/13/10注册
108 声望
创作了3篇指南
徽章: 5
+ 2更多徽章
CPSU-AMIDO-S10S27G92
4 名成员
创作了7篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 2,630
