跳转到主内容
Disassembling Onkyo TX-800 Logic board
你所需要的
  1. Disassembling Onkyo TX-800 Logic board, Disassembling Onkyo TX-800 Top case: 步骤 1 中的图像 1,3 Disassembling Onkyo TX-800 Logic board, Disassembling Onkyo TX-800 Top case: 步骤 1 中的图像 2,3 Disassembling Onkyo TX-800 Logic board, Disassembling Onkyo TX-800 Top case: 步骤 1 中的图像 3,3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Disassembling Onkyo TX-800 Logic board: 步骤 2 中的图像 1,2 Disassembling Onkyo TX-800 Logic board: 步骤 2 中的图像 2,2
    • Remove the top screw on the back panel.
  3. Disassembling Onkyo TX-800 Logic board: 步骤 3 中的图像 1,2 Disassembling Onkyo TX-800 Logic board: 步骤 3 中的图像 2,2
    • Slide off the case to expose the internal components of the receiver.
  4. Disassembling Onkyo TX-800 Logic board, Face plate: 步骤 4 中的图像 1,3 Disassembling Onkyo TX-800 Logic board, Face plate: 步骤 4 中的图像 2,3 Disassembling Onkyo TX-800 Logic board, Face plate: 步骤 4 中的图像 3,3
    • Unscrew the three screws on top of the face plate.
  5. Disassembling Onkyo TX-800 Logic board: 步骤 5 中的图像 1,2 Disassembling Onkyo TX-800 Logic board: 步骤 5 中的图像 2,2
    • Unscrew the one screw on the bottom of the front panel.
  6. Disassembling Onkyo TX-800 Logic board: 步骤 6 中的图像 1,3 Disassembling Onkyo TX-800 Logic board: 步骤 6 中的图像 2,3 Disassembling Onkyo TX-800 Logic board: 步骤 6 中的图像 3,3
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
  7. Disassembling Onkyo TX-800 Logic board, Logic board: 步骤 7 中的图像 1,3 Disassembling Onkyo TX-800 Logic board, Logic board: 步骤 7 中的图像 2,3 Disassembling Onkyo TX-800 Logic board, Logic board: 步骤 7 中的图像 3,3
    • On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
  8. Disassembling Onkyo TX-800 Logic board: 步骤 8 中的图像 1,2 Disassembling Onkyo TX-800 Logic board: 步骤 8 中的图像 2,2
    • You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
结论
另外一个人完成了本指南。
Ryan
于04/13/10注册
108 声望
创作了3篇指南
团队
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G92
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,645
