跳转到主内容
Disassembling Onkyo TX-800 Face plate
你所需要的
  1. Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: 步骤 1 中的图像 1,3 Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: 步骤 1 中的图像 2,3 Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: 步骤 1 中的图像 3,3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Disassembling Onkyo TX-800 Face plate: 步骤 2 中的图像 1,2 Disassembling Onkyo TX-800 Face plate: 步骤 2 中的图像 2,2
    • Remove the top screw on the back panel.
  3. Disassembling Onkyo TX-800 Face plate: 步骤 3 中的图像 1,2 Disassembling Onkyo TX-800 Face plate: 步骤 3 中的图像 2,2
    • Slide off the case to expose the internal components of the receiver.
  4. Disassembling Onkyo TX-800 Face plate, Face plate: 步骤 4 中的图像 1,3 Disassembling Onkyo TX-800 Face plate, Face plate: 步骤 4 中的图像 2,3 Disassembling Onkyo TX-800 Face plate, Face plate: 步骤 4 中的图像 3,3
    • Unscrew the three screws on top of the face plate.
  5. Disassembling Onkyo TX-800 Face plate: 步骤 5 中的图像 1,2 Disassembling Onkyo TX-800 Face plate: 步骤 5 中的图像 2,2
    • Unscrew the one screw on the bottom of the front panel.
  6. Disassembling Onkyo TX-800 Face plate: 步骤 6 中的图像 1,3 Disassembling Onkyo TX-800 Face plate: 步骤 6 中的图像 2,3 Disassembling Onkyo TX-800 Face plate: 步骤 6 中的图像 3,3
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
结论
2等其他人完成本指南。
Ryan
于04/13/10注册
108 声望
创作了3篇指南
团队
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G92
4 名成员
创作了7篇指南
2条评论
I would like to remove Front Face plate of my Onkyo TX-SR875 AV Receiver. Please guide me how can I open it?
Ashish Solanki - 回复
My Onkyo DX-C370 was “working fine..” until the belts started breaking. Following your disassembly and re-assembly guide, I replaced 3-belts using medium tension O-rings. Drawer opens/closes…, BUT carousel “studders” as it enters the pick-up unit, which does not engage with disk on “PLAY” button depression. I have Service Manual from online source.., and would like to follow “ERROR MESSAGE displays in “Heat-Running Mode” BUTY…, I do not know which panel button corresponds to the “DOWN BUTTON”.., Can You advise on how to get it spinning and playing CDs again..?
Much Thanks, Dom. Mendola, Ph.D. UCSD, Scripps Institution of Oceanography, Retired…
Dominick Mendola - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 3,870
