跳转到主内容
Disassembling Olympus Stylus Tough 6020 Prerequisite Guide
你所需要的
  1. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Battery: 步骤 1 中的图像 1,1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 步骤 2 中的图像 1,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 步骤 2 中的图像 2,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: 步骤 2 中的图像 3,3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 步骤 3 中的图像 1,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 步骤 3 中的图像 2,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: 步骤 3 中的图像 3,3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: 步骤 4 中的图像 1,2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: 步骤 4 中的图像 2,2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 步骤 5 中的图像 1,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 步骤 5 中的图像 2,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: 步骤 5 中的图像 3,3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 步骤 6 中的图像 1,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 步骤 6 中的图像 2,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: 步骤 6 中的图像 3,3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 步骤 7 中的图像 1,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 步骤 7 中的图像 2,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: 步骤 7 中的图像 3,3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Back Plate: 步骤 8 中的图像 1,1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 步骤 9 中的图像 1,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 步骤 9 中的图像 2,3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: 步骤 9 中的图像 3,3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 752
