跳转到主内容
Disassembling Olympus Stylus 725 SW Side Panels
你所需要的
  1. Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: 步骤 1 中的图像 1,2 Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: 步骤 1 中的图像 2,2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: 步骤 2 中的图像 1,3 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: 步骤 2 中的图像 2,3 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: 步骤 2 中的图像 3,3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  3. Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: 步骤 3 中的图像 1,3 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: 步骤 3 中的图像 2,3 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: 步骤 3 中的图像 3,3
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  4. Disassembling Olympus Stylus 725 SW Side Panels: 步骤 4 中的图像 1,3 Disassembling Olympus Stylus 725 SW Side Panels: 步骤 4 中的图像 2,3 Disassembling Olympus Stylus 725 SW Side Panels: 步骤 4 中的图像 3,3
    • After removing all four of the screws, pry the side covers off of the camera.
结论
Bobby Hodges
于04/18/10注册
49 声望
创作了6篇指南
团队
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G71
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 2,834
