跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide provides instructions for disassembling a broken LCD screen on the Olympus Stylus 725.
可选工具
配件
没有特定配件。
  1. The battery is located on the bottom of the camera. Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the buttom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • Charge the battery for 60-90 minutes if your battery is dead.
    • When installing a charged battery, align the battery appropriately, with the positive signs and negative signs lining up.
  2. Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver. Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver. Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
    • Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver.
    • Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
  3. Be careful when removing the back cover, you will need to detach the connecting ribbons Detach the ribbons using your thumb, sliding them out of their slots.
    • Be careful when removing the back cover, you will need to detach the connecting ribbons
    • Detach the ribbons using your thumb, sliding them out of their slots.
  4. Use a #00 Phillips head screwdriver to remove the screws in the back panel. After removing the back panel,  slide the ribbons off the computer chip to detach them. After removing the back panel,  slide the ribbons off the computer chip to detach them.
    • Use a #00 Phillips head screwdriver to remove the screws in the back panel.
    • After removing the back panel, slide the ribbons off the computer chip to detach them.
  5. Use tweezers to remove the loosened LCD screen. Be careful to not scratch the new LCD screen when replacing it.
    • Use tweezers to remove the loosened LCD screen.
    • Be careful to not scratch the new LCD screen when replacing it.
    • Carefully place the new screen in place of the old, making sure the label faces up.
    • Slide the ribbons back onto the computer chip.
    • Using the #00 Phillips head screwdriver from before, screw the screws in the back into the panel.
结论
Be sure to test the device by turning it on once the screen has been replaced. Make sure that the new screen works properly.
另外一个人完成了本指南。
Bobby Hodges
于2010年04月18日注册
49 信誉积分
创作了6篇指南
团队
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G71
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 7,738
