本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove the front panel to access the components inside.
你所需要的
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
Remove the top screws using a 1.5 mm screwdriver.
Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
即将完成!
结论
