跳转到主内容
加入维修社区 - 创建账户
Disassembling Olympus Stylus 1010 Case
你所需要的
  1. Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: 步骤 1 中的图像 1,2 Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: 步骤 1 中的图像 2,2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Disassembling Olympus Stylus 1010 Case: 步骤 2 中的图像 1,1
    • Remove the right side panel by pulling off the large silver piece.
  3. Disassembling Olympus Stylus 1010 Case: 步骤 3 中的图像 1,2 Disassembling Olympus Stylus 1010 Case: 步骤 3 中的图像 2,2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Disassembling Olympus Stylus 1010 Case: 步骤 4 中的图像 1,1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Disassembling Olympus Stylus 1010 Case: 步骤 5 中的图像 1,1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Disassembling Olympus Stylus 1010 Case: 步骤 6 中的图像 1,3 Disassembling Olympus Stylus 1010 Case: 步骤 6 中的图像 2,3 Disassembling Olympus Stylus 1010 Case: 步骤 6 中的图像 3,3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Disassembling Olympus Stylus 1010 Case: 步骤 7 中的图像 1,3 Disassembling Olympus Stylus 1010 Case: 步骤 7 中的图像 2,3 Disassembling Olympus Stylus 1010 Case: 步骤 7 中的图像 3,3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
结论
另外一个人完成了本指南。
Max McIntyre
于01/21/11注册
544 声望
创作了4篇指南
团队
Cal Poly, Team 13-4, Forte Winter 2011 Cal Poly, Team 13-4, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G4
6 名成员
创作了12篇指南
1指南评论
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 42
总计 3,367
