跳转到主内容
Disassembling Olympus FE-170 Casing
你所需要的
  1. Disassembling Olympus FE-170 Casing, Casing: 步骤 1 中的图像 1,2 Disassembling Olympus FE-170 Casing, Casing: 步骤 1 中的图像 2,2
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Disassembling Olympus FE-170 Casing: 步骤 2 中的图像 1,2 Disassembling Olympus FE-170 Casing: 步骤 2 中的图像 2,2
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Disassembling Olympus FE-170 Casing: 步骤 3 中的图像 1,2 Disassembling Olympus FE-170 Casing: 步骤 3 中的图像 2,2
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Disassembling Olympus FE-170 Casing: 步骤 4 中的图像 1,1
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Disassembling Olympus FE-170 Casing: 步骤 5 中的图像 1,1
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Disassembling Olympus FE-170 Casing: 步骤 6 中的图像 1,2 Disassembling Olympus FE-170 Casing: 步骤 6 中的图像 2,2
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Disassembling Olympus FE-170 Casing: 步骤 7 中的图像 1,2 Disassembling Olympus FE-170 Casing: 步骤 7 中的图像 2,2
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Disassembling Olympus FE-170 Casing: 步骤 8 中的图像 1,2 Disassembling Olympus FE-170 Casing: 步骤 8 中的图像 2,2
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
结论
CCrane
于03/26/15注册
201 声望
创作了2篇指南
团队
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 的会员
BU-SHAVER-S15S6G4
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 644
