跳转到主内容
Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017)
你所需要的
  1. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: 步骤 1 中的图像 1,2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Recommended Tools: 步骤 1 中的图像 2,2
    • Plastic spudgers/opening tools
    • T2 Torx Screwdriver
  2. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the battery compartment: 步骤 2 中的图像 1,1
    • Use a narrow-tipped object (such as a ballpoint pen or the tip of the T2 Torx Screwdriver) to depress the dimple on the battery compartment to release it
    • Replacement batteries are two (2) CR 2032 coin cell batteries.
  3. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: 步骤 3 中的图像 1,2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the front face: 步骤 3 中的图像 2,2
    • Gently pry along the edges of the remote using your fingers and prying tools to release the plastic clips.
    • It works best to start from the battery compartment and slowly work your way up to the top of the remote where the IR blaster is located.
    • Once the plastic clips are released, there is adhesive along the length of the volume sensor bar holding the front face in place. Slowly pry the face away from the rest of the remote and adjust your grip to avoid snapping the thin plastic face.
  4. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: 步骤 4 中的图像 1,2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Removing the mainboard: 步骤 4 中的图像 2,2
    • There are (6) T2 Torx screws holding the mainboard to the frame of the remote.
    • Two clips hold the mainboard in place. Slightly lift the top of the mainboard up and slide it towards the top of the remote to remove it from the frame.
  5. Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: 步骤 5 中的图像 1,2 Disassembling Nvidia Shield Pro Android TV Nvidia Shield Remote (2017), Disassembled: 步骤 5 中的图像 2,2
    • The remote should now be fully disassembled.
结论
另外一个人完成了本指南。
Skeven
于04/21/25注册
152 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 25
总计 194
