跳转到主内容
Disassembling Numark TT1600 Circuit board
你所需要的
  1. Disassembling Numark TT1600 Circuit board, Circuit board: 步骤 1 中的图像 1,2 Disassembling Numark TT1600 Circuit board, Circuit board: 步骤 1 中的图像 2,2
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Disassembling Numark TT1600 Circuit board: 步骤 2 中的图像 1,1
    • Remove the back cover by pulling it apart.
  3. Disassembling Numark TT1600 Circuit board: 步骤 3 中的图像 1,1
    • Locate the largest circuit board inside the device.
  4. Disassembling Numark TT1600 Circuit board: 步骤 4 中的图像 1,1
    • Locate the wires that are plugged into the side of the circuit board.
  5. Disassembling Numark TT1600 Circuit board: 步骤 5 中的图像 1,2 Disassembling Numark TT1600 Circuit board: 步骤 5 中的图像 2,2
    • Gently pull out the wires plugged into the circuit board.
  6. Disassembling Numark TT1600 Circuit board: 步骤 6 中的图像 1,2 Disassembling Numark TT1600 Circuit board: 步骤 6 中的图像 2,2
    • Once the wires are unplugged you will notice two more wires plugged into the bottom of the circuit board.
    • Note that these wires are soldered onto the circuit, indicated by the red markers.
    • To completely remove the circuit board these wires must be removed.
结论
另外一个人完成了本指南。
Sukhjinder
于10/12/11注册
17 声望
撰写一个指南
团队
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 的会员
CPSU-REGAN-F11S17G14
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,517
