当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the back cover to access the battery. Press the tab on the bottom of the cover.
Slide the back cover downwards off of the phone while pressing the tab down.
Locate the bottom-left corner of the phone where there is a spot to remove the battery.
Lift the battery out using your finger.
The E61i uses a Nokia BP-4L standard battery.
Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
Remove the cover by pulling it up and off.
Take off the casing and keyboard.
Remove the screws while holding the screen in place using a Torx T6 screwdriver.
Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
Lift the ribbon off of the contact with the motherboard.
Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
Gently pull the screen off of the phone.
Be sure not to rip the sticker that connects the display and the motherboard.
Pull the silver case off to completely free the cracked or damaged screen.
Pull the green motherboard from the back casing.
After the logic board has been removed, there is nothing else securing the antenna to the back cover. Simply remove the antenna by pushing outward from the interior side.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与7其他贡献者
于04/07/11注册
208 声望
创作了12篇指南
徽章: 10
+ 7更多徽章
CPSU-WALTERS-S11S9G63
5 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 15
总计 1,973
