跳转到主内容
Nokia Classic 2600c-2b Camera Replacement
你所需要的
  1. Nokia Classic 2600c-2b Camera Replacement, Camera: 步骤 1 中的图像 1,2 Nokia Classic 2600c-2b Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover to expose the battery. Put the plastic cover in a safe location for later.
  3. Nokia Classic 2600c-2b Camera Replacement: 步骤 3 中的图像 1,2 Nokia Classic 2600c-2b Camera Replacement: 步骤 3 中的图像 2,2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out by putting your finger in the small indent.
  4. Nokia Classic 2600c-2b Camera Replacement: 步骤 4 中的图像 1,2 Nokia Classic 2600c-2b Camera Replacement: 步骤 4 中的图像 2,2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Nokia Classic 2600c-2b Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the faceplate with the number pad attached and put the faceplate to the side.
  6. Nokia Classic 2600c-2b Camera Replacement: 步骤 6 中的图像 1,1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Camera Replacement: 步骤 7 中的图像 1,2 Nokia Classic 2600c-2b Camera Replacement: 步骤 7 中的图像 2,2
    • Remove the six screws along the edges of the phone using a Torx 5 screwdriver.
  8. Nokia Classic 2600c-2b Camera Replacement: 步骤 8 中的图像 1,2 Nokia Classic 2600c-2b Camera Replacement: 步骤 8 中的图像 2,2
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Camera Replacement: 步骤 9 中的图像 1,2 Nokia Classic 2600c-2b Camera Replacement: 步骤 9 中的图像 2,2
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell. Place the metal display in a safe location for reassembly.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Camera Replacement: 步骤 10 中的图像 1,1
    • Turn the motherboard over and locate the orange ribbon tape connecting the display to the motherboard.
    • Gently pull the tape up to remove the display.
  11. Nokia Classic 2600c-2b Camera Replacement: 步骤 11 中的图像 1,1
    • Locate the camera component in the plastic shell removed from underneath the motherboard (It is one piece).
    • Gently pull out the camera component using either a finger or plastic opening tool.
结论
2等其他人完成本指南。
Ian VanZandt
于02/14/12注册
654 声望
创作了5篇指南
团队
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 的会员
JMU-KLEIN-S12S3G1
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,248
