跳转到主内容
Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly
你所需要的
  1. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: 步骤 1 中的图像 2,2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 步骤 2 中的图像 1,1
    • Push the battery down from the top and pull it out.
  3. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 步骤 3 中的图像 1,1
    • Grip the front cover from the bottom.
  4. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 步骤 4 中的图像 1,1
    • Lift the front cover off.
  5. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 步骤 5 中的图像 1,1
    • Remove the six screws using a T6 torx screwdriver.
  6. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 步骤 6 中的图像 1,1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 步骤 7 中的图像 1,1
    • Remove assembly from phone
结论
Colby Leslie
于10/05/10注册
13 声望
创作了7篇指南
团队
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G3
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,188
