简介
This guides you through removing the keypad.
你所需要的
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Insert the head of the 2.5mm screwdriver into the indention.
Slide the screwdriver upward to a second indention at the top of the phone.
The front casing will detach from the model.
With the front casing removed, the keypad can easily be pulled off the back of the front casing.
In all probability, it will already have fallen out and no removal is required.
另外一个人完成了本指南。
