跳转到主内容
Disassembling Nokia 6236i Front Casing
你所需要的
  1. Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Battery: 步骤 1 中的图像 2,2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Disassembling Nokia 6236i Front Casing: 步骤 2 中的图像 1,3 Disassembling Nokia 6236i Front Casing: 步骤 2 中的图像 2,3 Disassembling Nokia 6236i Front Casing: 步骤 2 中的图像 3,3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Disassembling Nokia 6236i Front Casing, Removing Nokia 6236i Sim Card: 步骤 3 中的图像 1,3 Disassembling Nokia 6236i Front Casing, Removing Nokia 6236i Sim Card: 步骤 3 中的图像 2,3 Disassembling Nokia 6236i Front Casing, Removing Nokia 6236i Sim Card: 步骤 3 中的图像 3,3
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
  4. Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Front Casing: 步骤 4 中的图像 1,3 Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Front Casing: 步骤 4 中的图像 2,3 Disassembling Nokia 6236i Front Casing, Disassembling Nokia 6236i Front Casing: 步骤 4 中的图像 3,3
    • At the bottom right side of the device, there will be an indention.
    • Insert the head of the 2.5mm screwdriver into the indention.
    • Slide the screwdriver upward to a second indention at the top of the phone.
    • The front casing will detach from the model.
结论
The front casing will be detached without causing damage to the case or phone model.
For reassembly, complete the listed steps in reverse.
Erik Lindahl
于04/18/10注册
63 声望
创作了4篇指南
团队
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G46
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,841
