简介
This guide will give step-by-step instructions for removing the Nokia 6236i front casing without damage. This action may be considered if the front case is cracked, needs in-depth cleaning, or keyboard buttons need replacement.
你所需要的
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
The sim card is underneath and can now be removed.
Insert a spudger into the indention on the bottom right side of the device.
Slide the spudger upward to a second indention at the top of the phone.
The front casing will detach from the phone.
The front casing will be detached without causing damage to the case or phone model.
For reassembly, complete the listed steps in reverse.
