跳转到主内容
加入维修社区 - 创建账户
Disassembling Nokia 6086 Upper Back Cover
你所需要的
  1. Disassembling Nokia 6086 Upper Back Cover, Battery: 步骤 1 中的图像 1,1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Upper Back Cover: 步骤 2 中的图像 1,3 Disassembling Nokia 6086 Upper Back Cover: 步骤 2 中的图像 2,3 Disassembling Nokia 6086 Upper Back Cover: 步骤 2 中的图像 3,3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Upper Back Cover: 步骤 3 中的图像 1,3 Disassembling Nokia 6086 Upper Back Cover: 步骤 3 中的图像 2,3 Disassembling Nokia 6086 Upper Back Cover: 步骤 3 中的图像 3,3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Upper Back Cover, Upper Back Cover: 步骤 4 中的图像 1,1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
  5. Disassembling Nokia 6086 Upper Back Cover: 步骤 5 中的图像 1,2 Disassembling Nokia 6086 Upper Back Cover: 步骤 5 中的图像 2,2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
  6. Disassembling Nokia 6086 Upper Back Cover: 步骤 6 中的图像 1,2 Disassembling Nokia 6086 Upper Back Cover: 步骤 6 中的图像 2,2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
  7. Disassembling Nokia 6086 Upper Back Cover: 步骤 7 中的图像 1,3 Disassembling Nokia 6086 Upper Back Cover: 步骤 7 中的图像 2,3 Disassembling Nokia 6086 Upper Back Cover: 步骤 7 中的图像 3,3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
结论
Andrea
于04/15/10注册
70 声望
创作了5篇指南
团队
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G30
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 35
总计 2,372
