跳转到主内容
加入维修社区 - 创建账户
Disassembling Nokia 6086 Top Front Cover
你所需要的
  1. Disassembling Nokia 6086 Top Front Cover, Battery: 步骤 1 中的图像 1,1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 6086 Top Front Cover: 步骤 2 中的图像 1,3 Disassembling Nokia 6086 Top Front Cover: 步骤 2 中的图像 2,3 Disassembling Nokia 6086 Top Front Cover: 步骤 2 中的图像 3,3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Disassembling Nokia 6086 Top Front Cover: 步骤 3 中的图像 1,3 Disassembling Nokia 6086 Top Front Cover: 步骤 3 中的图像 2,3 Disassembling Nokia 6086 Top Front Cover: 步骤 3 中的图像 3,3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
  4. Disassembling Nokia 6086 Top Front Cover, Top Front Cover: 步骤 4 中的图像 1,1
    • Close the phone.
    • Face the front cover forward.
  5. Disassembling Nokia 6086 Top Front Cover: 步骤 5 中的图像 1,2 Disassembling Nokia 6086 Top Front Cover: 步骤 5 中的图像 2,2
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
  6. Disassembling Nokia 6086 Top Front Cover: 步骤 6 中的图像 1,3 Disassembling Nokia 6086 Top Front Cover: 步骤 6 中的图像 2,3 Disassembling Nokia 6086 Top Front Cover: 步骤 6 中的图像 3,3
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
结论
另外一个人完成了本指南。
Andrea
于04/15/10注册
70 声望
创作了5篇指南
团队
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G30
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 44
总计 2,468
