当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Press down on the release latch on the bottom of the cover.
Once the latch is released, lift the cover from the phone.
Lift the front case off of the phone body.
Lift the keypad off of the phone.
The screen is held to the body by six screws.
Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
Insert a flat screwdriver between the black body and plastic layer.
Pry the layers apart. The LCD and plastic layer will lift out as one piece.
With the screws removed, the logic board can then be lifted out of the body by hand.
取消:我没有完成这个指南。
与5其他贡献者
于04/18/10注册
1 声望
创作了8篇指南
徽章: 5
+ 2更多徽章
CPSU-GARNER-S10S30G39
5 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,849
