跳转到主内容
Disassembling Nokia 3560 Logic Board
你所需要的
  1. Disassembling Nokia 3560 Logic Board, Back Cover: 步骤 1 中的图像 1,2 Disassembling Nokia 3560 Logic Board, Back Cover: 步骤 1 中的图像 2,2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Logic Board, Disassembling Nokia 3560 Keypad: 步骤 2 中的图像 1,1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Logic Board: 步骤 3 中的图像 1,2 Disassembling Nokia 3560 Logic Board: 步骤 3 中的图像 2,2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Logic Board, Disassembling Nokia 3560 LCD Display: 步骤 4 中的图像 1,1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Logic Board: 步骤 5 中的图像 1,1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Logic Board: 步骤 6 中的图像 1,2 Disassembling Nokia 3560 Logic Board: 步骤 6 中的图像 2,2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Logic Board: 步骤 7 中的图像 1,1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Logic Board, Disassembling Nokia 3560 Logic Board: 步骤 8 中的图像 1,1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
结论
Sam Ryan
于04/18/10注册
1 声望
创作了8篇指南
团队
Cal Poly, Team 30-39, Garner Spring 2010 Cal Poly, Team 30-39, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G39
5 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,971
