跳转到主内容
Disassembling Nokia 3560 Charging Port and Power Connector
你所需要的
  1. Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: 步骤 1 中的图像 1,2 Disassembling Nokia 3560 Charging Port and Power Connector, Back Cover: 步骤 1 中的图像 2,2
    • Press down on the release latch on the bottom of the cover.
    • Once the latch is released, lift the cover from the phone.
  2. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Keypad: 步骤 2 中的图像 1,1
    • Lift the front case off of the phone body.
  3. Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 3 中的图像 1,2 Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 3 中的图像 2,2
    • Lift the keypad off of the phone.
  4. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 LCD Display: 步骤 4 中的图像 1,1
    • The screen is held to the body by six screws.
  5. Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 5 中的图像 1,1
    • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  6. Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 6 中的图像 1,2 Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 6 中的图像 2,2
    • Insert a flat screwdriver between the black body and plastic layer.
  7. Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 7 中的图像 1,1
    • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  8. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Logic Board: 步骤 8 中的图像 1,1
    • With the screws removed, the logic board can then be lifted out of the body by hand.
  9. Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 9 中的图像 1,2 Disassembling Nokia 3560 Charging Port and Power Connector, Disassembling Nokia 3560 Charging Port and Power Connector: 步骤 9 中的图像 2,2
    • These two parts can be removed with your fingers.
    • Make sure not to bend the metal contacts.
结论
Sam Ryan
于04/18/10注册
1 声望
创作了8篇指南
团队
Cal Poly, Team 30-39, Garner Spring 2010 Cal Poly, Team 30-39, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G39
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 17
总计 3,295
