跳转到主内容
Disassembling Nokia 3395 Logic Board
你所需要的
  1. Disassembling Nokia 3395 Logic Board, Back Case: 步骤 1 中的图像 1,3 Disassembling Nokia 3395 Logic Board, Back Case: 步骤 1 中的图像 2,3 Disassembling Nokia 3395 Logic Board, Back Case: 步骤 1 中的图像 3,3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Logic Board, Battery: 步骤 2 中的图像 1,2 Disassembling Nokia 3395 Logic Board, Battery: 步骤 2 中的图像 2,2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Logic Board, Front Case: 步骤 3 中的图像 1,2 Disassembling Nokia 3395 Logic Board, Front Case: 步骤 3 中的图像 2,2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Logic Board, Screen: 步骤 4 中的图像 1,2 Disassembling Nokia 3395 Logic Board, Screen: 步骤 4 中的图像 2,2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Logic Board: 步骤 5 中的图像 1,2 Disassembling Nokia 3395 Logic Board: 步骤 5 中的图像 2,2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Logic Board, Logic Board: 步骤 6 中的图像 1,2 Disassembling Nokia 3395 Logic Board, Logic Board: 步骤 6 中的图像 2,2
    • Remove logic board as shown.
结论
3等其他人完成本指南。
Nico Lee
于04/19/10注册
78 声望
创作了6篇指南
团队
Cal Poly, Team 30-41, Garner Spring 2010 Cal Poly, Team 30-41, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G41
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,880
